Date/Time: Mon, 16 Sep 2024 19:13:53 +0000
True range
View Count: 219
[2023-05-26 08:54:38] |
Pedro7 - Posts: 22 |
Hi, Is there a study that indicates the true range of a bar in value. Eg. ES bar of 4 points shows 200 $ (1 contract, 1 point is 50 $ times 4). Thx |
[2023-05-26 14:17:54] |
John - SC Support - Posts: 34451 |
There is not a study that does this directly, but you can put it together easily enough. Just use the "True Range" study along with the Arithmetic Studies (or the Spreadsheet Formula) to get what you want. Refer to the following: True Range Using the Basic Arithmetic Studies Spreadsheet Formula For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
