Date/Time: Fri, 14 Mar 2025 12:41:57 +0000
[User Discussion] - How to prevent auto trading at existing entry price?
View Count: 342
[2023-05-26 01:13:24] |
j4ytr4der_ - Posts: 946 |
I've come up with a cumbersome solution to this in spreadsheets, but I'm wondering if anyone has a better solution, in particular one that works when using the Trading System Based On Alert Formula study. If the system is allowed multiple entries in the same direction, it will continually enter at the identical price level if the signal is present. Ideally there would be an option for "Disallow entry at existing entry price" that would address this. In Spreadsheets, what I've done is on entry, check the last entry price and make sure it doesn't match the current entry price. If they match, no valid entry. This works but is a messy additional bit of logic needed in the entry formula cells. Would love a cleaner solution. Anyone know of one? Date Time Of Last Edit: 2023-05-26 01:39:29
