Date/Time: Thu, 28 Nov 2024 03:53:25 +0000
Multiple synced chartbooks
View Count: 396
[2023-05-25 07:46:34] |
Mattx - Posts: 12 |
I want to have a chartbook with a few windows for a symbol, and then open exactly the same charbook for another symbol. I think the current way to go right now is to duplicate the chartbook file and create a chartbook group so both are opened together. The problem with this approach is if you change something in one chartbook, let's say the settings of a study, this new config won't be reflected on the other chartbook. The use case here is really simple. I want to keep track of multiple symbols during a session and my set of windows is the same for all of them. Of course I can just switch between symbols using a watchlist but it's quicker to change chartbooks so there is no data loading delay every time you switch between them, which is quite often. I hope it makes sense. So is there a way to open the same chartbook twice, or two synced chartbooks, in a way that a change in one is applied to the other one? At least next time you open them if not right away. |
[2023-05-25 14:00:43] |
There is not a way to sync the displays between Chartbooks.
[2023-05-30 03:03:43] |
User624595 - Posts: 207 |
You can use intraday file update list to have the intraday data downloaded for multiple symbols even without charts open, so if you switch, the data loading should be quicker.
[2023-05-30 10:15:45] |
Mattx - Posts: 12 |
Where is that update list?
[2023-05-30 16:04:59] |
Global Settings Menu: Intraday File Update List (Global Settings menu)
