Date/Time: Thu, 28 Nov 2024 05:37:03 +0000
Download filing after update to latest version
View Count: 235
[2023-05-25 03:57:31] |
User755385 - Posts: 2 |
I just updated to the latest version because my data download had stopped work since I was on an older version. After the update, I cannot download and I get the following message. I do not know how to fix this. I am running on a Windows 10 system. File compression not supported on file system. G:\Other computers\My Laptop\SierraChart\Data\QLYS.dly. Windows error code 1: Incorrect function. | 2023-05-24 20:40:56.603 |
[2023-05-25 13:32:47] |
Sierra_Chart Engineering - Posts: 17199 |
Disable file compression: Advanced Service Settings: Support Intraday and Market Depth Files Compression (Global Settings >> Advanced Service Settings >> Other) Restart Sierra Chart after you do this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-25 13:33:06
