Date/Time: Thu, 28 Nov 2024 05:54:19 +0000
Sierra Chart Automatic Login
View Count: 247
[2023-05-24 22:04:23]
AndyBisulca - Posts: 21
Hello
I am considering running Sierra Chart on a VPS.
One of my concerns is how to automatically login to Sierra Chart in the event of a VPS restart.
Please explain if automatic login is supported or if there is a workaround.
Thank you in advance for your support.
Warmest Regards
Andy
[2023-05-24 22:52:51]
John - SC Support - Posts: 36350
Sierra Chart does not have any automatic starting capabilities itself. If the VPS is completely restarted, then Sierra Chart (by default) would not be started.
Once Sierra Chart is started, it does automatically log you in using the last used Account Name and password.
Therefore, you would need to setup the Operating System to Automatically Start the Sierra Chart executable when the system restarts.
