Date/Time: Thu, 28 Nov 2024 05:48:56 +0000
Rectangle drawings issue
View Count: 566
[2023-05-24 03:26:00] |
User895691 - Posts: 6 |
I am having issues with the rectangle drawing tool. All other tools are working ok. The usual way I draw a line or rectangle is by left clicking on starting point on the chart, dragging mouse to end point (while left click is still pressed) and then releasing at the end point. This way line tool is working fine. But for rectangles (normal or extended), I dont see the left click being activated. Rectangles are being drawn on the chart but I dont see the crossover moving around while I draw the shape. What am I doing wrong?
[2023-05-24 08:43:18] |
Sierra_Chart Engineering - Posts: 17199 |
We are not exactly sure what you mean by this: Rectangles are being drawn on the chart but I dont see the crossover moving around while I draw the shape. However, refer to this setting:Chart Drawing Tools: Action When Other Tools Selected (Global Settings >> Tool Settings >> Chart Values >> Chart Values) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-24 09:03:05] |
I have not changed any of these suggested settings. So when you draw say a line, you can see the shape of the line while you drag it with mouse pressed. Same with rectangles - you press the mouse, drag the mouse vertically or horizontally first then drop it where you want the rectangle to form. While you are dragging the mouse, you can see outline of the drawing (rectangle). In my case, I don't see any rectangle lines getting formed until I complete the drawing by the closing left click. I can then see the rectangle shape but nothing while my mouse is clicked and I am moving it around to draw the rectangle. I have no trouble with any other tool - only the main rectangle and the extended version. Same issue in both. Please advise. Thanks |
[2023-05-24 11:25:03] |
What is the background color of the chart? You are going to need to change the outline color of the rectangle drawing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-24 11:25:14
[2023-05-24 13:00:04] |
brilliant - that was the issue as I have black background and selected black outline for my rectangles. Thank you for this resolution.
