Date/Time: Thu, 28 Nov 2024 05:55:17 +0000
Daily loss limit form Teton
View Count: 362
[2023-05-23 15:47:48] |
OriolCasas - Posts: 163 |
Hello, I am now running Teton which I think has a proper daily loss limit. Do I have to set it up from my broker, Sierra Chart or here through the support? Some time ago when I was using Denali through CQG i messaged AMP and they couldn't set up a daily loss limit. Thank you |
[2023-05-24 08:47:02] |
Sierra_Chart Engineering - Posts: 17199 |
There is a daily loss limit available through Teton but you do not want to be relying upon that because your broker likely would charge you extra when that is triggered. We are still developing a daily loss limit that you can control yourself for Teton order routing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-24 08:47:09
