Date/Time: Thu, 28 Nov 2024 05:37:41 +0000
Trade Sync and Bracket Orders
View Count: 343
[2023-05-22 20:33:26]
Poparocks - Posts: 15
I have 2 questions:
1. Is there any way to sync trades between multiple accounts. Allowing me to trade 1 account and it will automatically place the same trade on another account of my choice.
2. What is the best way to setup a bracket order that would automatically place my risk at $4 and my Target at 2R. Once either is hit it would close down. Also if I was to adjust my risk manually would change my target order automatically.
[2023-05-22 23:44:27]
John - SC Support - Posts: 36350
1. Refer to the following for what is available within Sierra Chart:
Order Allocation to Trade Accounts
2. There is not a direct way to specify the amount of "Risk" and then have the attached orders adjust to that value.
You can specify a price and offset for the attached orders, which would give you the ability to specify the dollar amount of offset, but again, there is not a way to control this directly through this window.
The option you do have available, is to use the "Trade Management by Study" study, which allows you to adjust the Stops and Targets based on a study. You could create a line that is at the dollar offset you want and then adjust that line as you want, which would then change the attached orders. Refer to the following:
Attached Orders: Study Controlled Targets and Stops
[2023-05-23 20:41:23]
Is the Order Allocation to Trade Accounts only available on SIM accounts ? Will with work with APEX accounts ?
[2023-05-23 20:56:15]
gcUserStudies - Posts: 106
yes
