Date/Time: Thu, 28 Nov 2024 05:50:41 +0000
Technicail support
View Count: 226
[2023-05-22 18:41:22] |
User933370 - Posts: 1 |
hi alread buy the package 11 and nasdaq monthly.. but i still get dela data ?
[2023-05-22 18:53:30] |
Sierra_Chart Engineering - Posts: 17199 |
Make sure you are using the correct NASDAQ TotalView symbols. Refer to: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
