Date/Time: Thu, 28 Nov 2024 05:46:07 +0000
How to Show market depth during market replay using the DOM
View Count: 317
[2023-05-19 20:33:29]
Jimmyz83 - Posts: 52
I can not find the setting to achieve this. Attached is a pic showing the missing date and my replay settings.
tks
imageScreenshot 2023-05-19 152659.jpg / V - Attached On 2023-05-19 20:30:58 UTC - Size: 131.67 KB - 78 views
[2023-05-19 21:23:21]
John - SC Support - Posts: 36350
Refer to the following:
Replaying Charts: Replaying of Market Depth Data
And then also refer to the following for how to download historical Market Depth data if you do not already have it:
Market Depth Historical Graph: Downloading Of Historical Market Depth Data
[2023-05-19 22:14:04]
I have tried all of that without anything changing. I only get the top of the book with only 1 qty. I am on Denali with mbo data also, the sierra chart server setting are also attached in pic. I have downloaded and retried multiple times. I am only replaying todays session. What can I be doing wrong. Thanks for the help.
imageScreenshot 2023-05-19 171239.jpg / V - Attached On 2023-05-19 22:12:56 UTC - Size: 191.49 KB - 76 views
[2023-05-22 14:17:59]
Most likely you are not "recording" the market depth data in order to have it stored for the replay. The only way this occurs automatically is if you have the "Market Depth Historical Graph" displayed on a chart for that symbol. Otherwise, you need to follow the instructions regarding replaying Market Depth data to set the symbol settings to store the Market Depth data. Refer to the following:
