Date/Time: Mon, 16 Sep 2024 19:20:37 +0000
trade order
View Count: 1103
[2014-06-27 07:46:05] |
dez - Posts: 45 |
how to get the order? for instance open buy two contracts, stop 10 ticks and two target 5 and 10 ticks, and when you execute the first contract for 5 ticks, the stop is moved to the opening price of my order? I'm trying to do at home, but can not get it exactly how I want, it means that after the execution of one target immediately move stop to entry price, thanks |
[2014-06-27 07:53:11] |
dez - Posts: 45 |
which type of orders I put in it? means when you execute one target, to stop automated moved for 10 tick, means at my entry price, thanks
dom ....PNG / V - Attached On 2014-06-27 07:50:47 UTC - Size: 42.45 KB - 330 views |
[2014-06-28 01:32:23] |
we will put together an example for this.
[2014-06-29 08:34:37] |
dez - Posts: 45 |
ok, can wait .. for example, thanks
[2014-06-29 09:49:54] |
We have attached an image of the Targets tab showing how it needs to be configured to do what you want. Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
Attached Orders for Dez.png / V - Attached On 2014-06-29 09:49:49 UTC - Size: 12.83 KB - 327 views |
[2014-07-03 18:55:20] |
dez - Posts: 45 |
it does not work the way I want ... one contract is executed and stop remains at 10 tick ... I want to move to the second stop 10 tick. means when you make a profit of 5 tick, the second stop immediately moved for 10 tick, to protect the profits ..thanks
[2014-07-03 22:14:31] |
We made a slight mistake. Look at that image. Set the Trigger OCO Group to 2 for the Stop order.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-03 22:14:41
[2014-07-04 11:53:30] |
User57870 - Posts: 3 |
Hello I connect to the sierra chart but after send order in the platform, trade service log show me this log Trade Order Error - OEC order update (Rejected). Text: Invalid account. Unknown account(s). Internal Order ID: 17195. Service Order ID: OECFIX:635396724571646306:32359. Symbol: YMU4 | 2014-07-04 11:49:34 This message is on my home office but not in my work office. The chartbook is same in work and home. Thank you, Marek, Slovakia, Kosice Date Time Of Last Edit: 2014-07-04 18:10:17
Private File Private File |
[2014-07-04 20:44:40] |
The problem is that the Trade Account in File >> Data/Trade Service Settings is not set correctly. It is not supposed to be your OEC username but your account number that is associated with your OEC username. Find out what your account number is from OEC and enter that in the Trade Account box.
