Date/Time: Thu, 28 Nov 2024 05:52:40 +0000
Keyboard shortcuts transferring from within a subinstance
View Count: 309
[2023-05-19 13:07:17]
Steve Leon - Posts: 301
I created keyboard shortcuts in global settings in my subinstance #2
Is there a way for me to transfer these to my main instance and also another subinstance so i dont have to manually recopy them
Thank you
[2023-05-19 20:56:33]
John - SC Support - Posts: 36350
There is not a direct way to do this.
You would have to copy the "Sierra4.config" file from the sub-instance where you made the change to the other instances.
But, the Sierra4.config file contains more than just the Keyboard Shortcuts - it contains all the global settings for the system. If you want all your instances to look the same, then this should not be a problem, but if you have differences, then you might be best served to re-create the keyboard shortcuts in each instance.
[2023-05-22 14:46:14]
Sierra_Chart Engineering - Posts: 17199
Correction: Keyboard shortcuts are contained within:
KeyboardShortcuts4.config
So this file can be copied but it must only be copied when the instances are not running.
