Date/Time: Thu, 28 Nov 2024 07:57:53 +0000
Historical data logon error
View Count: 275
[2023-05-19 11:06:11] |
User840964 - Posts: 46 |
Hello, I'm getting the same error (please see the attached image) on a number of symbol that previously worked fine. They are: AI, WAL, CM, XHB, SH, PSH, BCE, IAU. That error shows either with or without the suffix "-nqtv". Please let me know how to fix it, if possible. |
AI_error_.png / V - Attached On 2023-05-19 11:03:37 UTC - Size: 13.71 KB - 75 views Attachment Deleted. |
[2023-05-19 11:39:10] |
Sierra_Chart Engineering - Posts: 17200 |
You need to update Sierra Chart to the latest version to solve this: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
