Date/Time: Thu, 28 Nov 2024 08:04:44 +0000
limit order help
View Count: 332
[2023-05-19 07:36:13] |
User895691 - Posts: 6 |
Hi, We have buy @ ask and sell @ bid buttons in the order entry panel. I am however looking to add offset to my limit orders. for instance, how can I place a limit buy order at ask + 2 ticks or place a limit sell order at bid - 2 ticks? I cant trade off the DOM so chart trading, order entry panel or hotkeys are doeable for me. Thank you. R |
[2023-05-19 17:59:25] |
When you using a Stop-Limit order, you can define an offset to be used with that Stop-Limit. Refer to the following: Basic Trading and the Trade Window: Set >> Stop-Limit Order Limit Offset For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
