Date/Time: Thu, 28 Nov 2024 07:52:11 +0000
Bar Close Graphics Settings
View Count: 308
[2023-05-19 07:35:50]
RIFT - Posts: 124
Can you please add Bar Up Close and Bar Down Close color settings so that when the bar falls and rises, the close has the same color as the bar, that would be very helpful for the HLC bars.
That would be great!
Thanks!
[2023-05-19 10:06:37]
Sierra_Chart Engineering - Posts: 17200
There is a Graphics Setting which effectively does this. Refer to:
Graphics Settings: Color Entire OHLC Bar the High/Low Color (Global Settings >> Graphics Settings >> Other)
