Date/Time: Thu, 28 Nov 2024 08:04:10 +0000
MGC position disappeared from sierra chart, using interactive brokers connection
View Count: 319
[2023-05-18 23:44:02] |
cuckiecheese - Posts: 63 |
Hi, So as I've gone in and out of position on MGC the last couple of days, I noticed something was off, so I checked TWS and saw that I indeed still have an MGC position open that does not show up on my chart. I checked the trade positions window in Sierra, and the position shows up there. I am currently using GC (june expiry) chart with MGC as trade symbol. I also tested an MGC (june expiry) chart and do not see the position on the chart. Where else can I look to fix this problem? Thanks I've gone through this documentation page for explanations to the cause of that but haven't found a solution yet. Interactive Brokers Trading Service |
[2023-05-19 00:05:43] |
Additional info: I have a position open on MCL, with the same setup CL chart, MCL trade symbol, and that works without issue. I don't know what happened to MGC recently, it's all been working fine up until this point.
[2023-05-19 17:40:01] |
You need to look through your Trade Activity Log to figure out what is missing. It sounds like there may not have been a response to the opening of the position, so Sierra Chart did not know if the position existed for sure.
