Date/Time: Thu, 28 Nov 2024 07:54:10 +0000
Denali data with AMP order routing
View Count: 367
[2023-05-18 13:28:09]
User192201 - Posts: 19
I tried to make sense of all the messages around this topic but didn't find a solution. so, I know it might be repeatative. Anyways
I have AMP account set and its knows I have sierra chart and using denali and I chose use CQG/Amp for order routing/execution only.
Now, how do I enable that in Sierra Chart please?
The only place I found was the Data Service but then it wants to use CQG data and wants to translate symbols to it instead of Denali / SC symbols.
so, I want to know how to make sure I have Denali Data service but sill use CQG/Amp -
do I have two run two instances of SC one each with different Data Services? That is the only "bad" solution that I could come up with.
Thank you
Raj
[2023-05-18 18:18:32]
Sierra_Chart Engineering - Posts: 17200
Follow the CQG set up instructions here:
CQG Trading Platform Service: Setup Instructions
And refer to:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
Only a single instance is needed.
