Date/Time: Thu, 28 Nov 2024 08:02:04 +0000
Target projection on TPO charts?
View Count: 305
[2023-05-18 11:31:41]
BenjFlame - Posts: 324
i'm looking to draw horizontal step line for each day on tpo chart.
For example, on each day, I would like a target step line calculated as day high + 25% of yesterday range.
Is this possible with any built-in tool, and if not, would it work with ACSIL ? This could easily be done on non TPO chart with ACSIL, but what about with TPO ?
[2023-05-19 15:40:39]
John - SC Support - Posts: 36350
You would have to use a different chart in order to get the calculations for the "Day High + 25% of Yesterday Range". And then use the "Study/Price Overlay" to overlay that data on the TPO.
But, when we did a quick test, we were only able to get the data to display on the current day for the TPO. Displaying information on the TPO chart can be a bit "tricky", as it is not as straightforward a graph as others. So this is where you will have the biggest issue. Refer to the following for what we are referring to:
Time Price Opportunity (TPO) Profile Charts: Using Other Studies on a TPO Chart
