Date/Time: Thu, 28 Nov 2024 07:50:10 +0000
[User Discussion] - order on NEW open of a bar
View Count: 351
[2023-05-17 18:59:27] |
Bram - Posts: 25 |
Hi there, is there a possibility or input to place an order when a new bar opens above a certain price level? like a 5m or 30m NEW bar which opens above a certein price level |
[2023-05-17 20:30:03] |
Use the "Trading System Based on Alert Condition" study and set your Alert Condition to be the following: =O > 3547.25 Where O is the Open of the bar and 3547.25 is just a number - you would put in whatever value you are wanting to test against. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-18 18:54:42] |
Bram - Posts: 25 |
already thanks for the quick response, much apreciated would this also be able when using the spreadsheet? |
[2023-05-18 21:20:57] |
Sawtooth - Posts: 4120 |
=B3 > 3547.25
