Date/Time: Thu, 28 Nov 2024 00:28:06 +0000
CME dairy symbols not found
View Count: 486
[2023-05-17 18:36:58] |
voided - Posts: 45 |
I wasn't able to find symbols for: Class III Milk: DC Class IV Milk: GDK Nonfat Dry Milk: GNF Dry Whey: DY Cash Settled Butter: CB Cash Settled Cheese: CSC Block Cheese: BLK I saw some old posts on the support board suggesting some of these are/were available, however. Am I doing something wrong, or are these contracts no longer supported? Date Time Of Last Edit: 2023-05-17 18:37:22
[2023-05-17 20:21:48] |
The only symbol in your list that is not listed on our Find Symbol page is BLK. But that symbol is not traded very much (the last few contracts have 0 volume in total). If they are not showing in your Find Symbol window, then let us know what your current service is set to, and it could be those symbols are not setup for that particular service. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-18 05:43:00] |
Thanks John, I am using the Denali feed, if that's what you mean by service. "Teton CME Order Routing" from "Data / Trade Service Settings" >> "Current Selected Service". My Sierra Chart version is 2476 64-bit, revision 44841M. No worries about BLK. Date Time Of Last Edit: 2023-05-18 05:46:43
[2023-05-19 15:06:24] |
These are not listed for the Teton Order Routing. Are these symbols you want to have available with the Teton Order Routing. They are not traded much. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-20 16:33:47] |
Yes, please. I am interested in the market data (I don't trade through Sierra Chart directly).
[2023-05-22 13:43:03] |
Sierra_Chart Engineering - Posts: 17199 |
Give us some time to set up these symbols.
[2023-06-08 16:24:45] |
Set up of these is still in progress.
[2023-06-14 16:07:43] |
We have made sure all of these symbols are set up along with providing real-time or delayed data for them for the SC Data - All Services service. To set this service, select Global Settings >> Data/Trade Service Settings >> Current Selected Service. What we recommend you do is install another installation of Sierra Chart to use this service separate from the installation of Sierra Chart you use with Teton order routing. Instructions: Using Multiple Data and Trading Services at the Same Time Unless you will be trading them we will not be setting them up for Teton order routing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-06-14 16:08:22
