Date/Time: Thu, 28 Nov 2024 07:48:59 +0000
DAS Trader routing within SC
View Count: 715
[2023-05-17 10:07:22] |
funbun - Posts: 90 |
I remember reading a post about an integration between SC and DAS Trader routing. Opening the option to route orders through DAS Trader effectively opens the door to many many stock brokers. DAS became very popular amongst stock traders. I'm using Guardian as my broker and DAS for routing. I imagine sending orders directly within SC platform, monitoring live orders/positions without peaking back and forth to different windows, that will be a game changer. No matter the cost I'm in! (Almost no one in the day trading community uses IB, they all use brokers that connect with DAS so I'm definitely not alone...) |
[2023-05-17 11:58:12] |
Sierra_Chart Engineering - Posts: 17200 |
We looked at this many years ago and we forgot what the reason was that we did not develop the integration to DAS Trader. There was some reason why.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-17 11:59:05
[2023-05-17 13:00:31] |
I loved the genuine answer :) Final technical question - With the tools we have at SC (ASCIL I believe) is it even possible to individually develop such a bridge? Or are these capabilities too deep into the system... |
[2023-05-17 15:17:51] |
Theoretically you could do it. You would use DTC to get the information out of Sierra Chart and then you would have to create another program to take that information and interface to DAS Trader. Refer to the information here: DTC Protocol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
