Date/Time: Thu, 28 Nov 2024 08:03:15 +0000
Keyboard Shortcut use attached orders
View Count: 455
[2023-05-17 06:40:39]
User230940 - Posts: 121
In the control bar I enable the Trading Function "Use attached Orders" to be able to enable and disable the defined attached orders fastly.
I am searching for a Keyboard Shortcut for this Function but I did not find any.
Is to possible to add this Keyboard Shortcut for "Use attached Orders"?
regards
[2023-05-17 14:27:40]
John - SC Support - Posts: 36350
There is a Keyboard Shortcut for "Use Attached Orders". It is with the "Trading Keyboard Shortcuts" section. Just below "Sell Stop Limit Bid -3 Ticks".
[2023-05-17 14:34:51]
Thanks, I was blind. sorry for interrupting you.
