Date/Time: Thu, 28 Nov 2024 07:58:52 +0000
Control Bar Button default Background for Active and not Active
View Count: 316
[2023-05-17 06:35:27]
User230940 - Posts: 121
since yesterday I use the Control Bar function, which is great.
Is it possible / would it be possible to be able to define a dedicated color for the Control Bar Button in case it is active?
I defined the Control Bar Button Default Background to a dark green.
Now it is dark green in case it is active and light green if not.
I would like to have a dedicated color for that.
Possible?
thanks
[2023-05-17 13:54:01]
John - SC Support - Posts: 36350
There is not an option to define two background colors for a Control Bar Button - one for not pressed and one for pressed. There is just the one background color option and the particular shade changes when pressed in (as you have noted).
[2023-05-17 14:07:52]
Would be nice. If you have nothing left to do... ;-)
regards
[2023-05-18 10:58:50]
HI,
found the properties on each Button in control bar. Enough and fine.
thanks
