Date/Time: Thu, 28 Nov 2024 07:52:56 +0000
specific alignment of detached charts
View Count: 244
[2023-05-17 01:23:16] |
User268812 - Posts: 21 |
Hi on charts that are detached how do I keep them in the same location that I set them on across my 3 screens? So, that on the next time I start Sierra back up they automatically pop up on that spot without me rearranging them once again. is this possible? Thank You
[2023-05-17 13:41:35] |
It should occur normally - the windows should restore back to the same location they were in when you saved and closed Sierra Chart. But, we have heard that this does not always work, but that is due to the Operating System not restoring the windows properly. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
