Date/Time: Thu, 28 Nov 2024 07:38:13 +0000
Is there a way to save multiple Rithmic account credentials?
View Count: 724
[2023-05-16 21:33:57]
Driss - Posts: 10
Hi SC Team,
I was wondering if there's any way to save multiple Rithmic accounts DTS config and just switch between them instead of typing it each time. I tried saving it through DTS Config, but I think it's storing the info at the service level, I'm looking something at server level. I have Apex and Leeloo both are under Rithmic Direct service but different servers. Currently, I have to type each one anytime I had to switch. Please let me know if there's any easy way.
[2023-05-16 22:04:11]
John - SC Support - Posts: 36350
The purpose of the DTS configurations is to do exactly what you are wanting. We just tried to see if there was an issue with this, but it is working as expected. Please try saving the different configurations and then loading them and see if everything properly updates for you (it should).
[2023-05-16 22:21:53]
Driss - Posts: 10
Yes, it's working, those buttons and list field are new to me, but now I know. Thanks for replying.
[2023-05-17 10:38:39]
Sierra_Chart Engineering - Posts: 17199
Here is the documentation:
Data/Trade Service Settings: Saved DTS Configuration (Global Settings >> Data/Trade Service Settings >> Main Settings)
