Date/Time: Thu, 28 Nov 2024 08:05:32 +0000
Config Send Attached Orders Position
View Count: 492
[2023-05-16 13:24:25]
Mattx - Posts: 12
From what I've seen when you send attached orders automatically (ie, by having "Use Attached Orders" enabled), those target and stop loss orders behave differently than sending them using "Send Attached Orders - Position".
In the second scenario:
1. The orders don't show the open P/L next to them on the chart
2. You cannot cancel one without canceling the other automatically
Is it possible to send those attached orders by "Send Attached Orders - Position" and make them equivalent to the first scenario where they're attached automatically? Ie, I want to show P/L next to them and cancel one without cancelling the other
[2023-05-17 21:48:49]
Sierra_Chart Engineering - Posts: 17200
No, this is not supported. Would be best to use Attached Orders, when the main order is submitted. If you are not sure where to place them, just initially set them to be more distant. And then you can adjust them closer.
Date Time Of Last Edit: 2023-05-17 21:50:01
