Date/Time: Thu, 28 Nov 2024 08:00:57 +0000
Intraday Trading Exchanges and Data Feed options
View Count: 379
[2023-05-16 11:38:28] |
User656978 - Posts: 3 |
Hello, I'm looking to reduce costs and keep the best quality of execution. I need CME Bundle, ICE Europe, EUREX Data Feeds. With all these Teton, Denali, Stage 5, CQG, AMP services and options. What is the best broker and data feed chose to connect to Exchanges above? I do trading intraday and currently use AMP broker with CQG to ICE EU and Denali for CME. Thank You for your help. |
[2023-05-16 14:41:04] |
You can stay with AMP (unless you just do not want to) but we recommend making one change - that is to setup a second account with AMP where you use the Teton Order Routing Service to trade the CME and then continue to use your current account with CQG to trade ICE and EUREX. You will continue to get the data for the CME Group and EUREX from us. The reason for this is that the Teton Order Routing only supports trading the CME Group. Therefore you will still need CQG to trade ICE and EUREX. If you do this, then you will want to have two installations of Sierra Chart, one to connect to the Teton Order Routing and the other to connect to CQG. Refer to the following for how to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart The instructions to setup the Teton Order Routing are at the following link: Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-18 15:45:20] |
If I want to use 2 accounts with AMP then my balances will be separated - so I need bigger account balance to cover both accounts margins. This is only the problem. Is there any huge advantage using Teton Order Routing instead of using Denali Data feed and trade with CQG (for CME)? Thank You |
[2023-05-18 18:09:46] |
Sierra_Chart Engineering - Posts: 17200 |
Yes there is an advantage and that is explained here: Sierra Chart Teton Futures Order Routing: Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
