Date/Time: Thu, 28 Nov 2024 07:54:37 +0000
New Bar at custom time (similar to new bar at session start)
View Count: 392
[2023-05-16 09:44:42]
User61168 - Posts: 403
Hello SC Support,
Is it possible to create a new bar at a specific time of day during a regular or overnight session? I need to replace the functionality of "new bar at session start" multiple times during the session. If this functionality is not currently available but possible via custom ASCIL programming, please let me know. I would appreciate it.
Edit: I need this to work on a Aligned Renko chart type.
Date Time Of Last Edit: 2023-05-16 09:46:34
[2023-05-16 14:36:35]
John - SC Support - Posts: 36350
You would have to create a custom study to do this. Refer to the following:
ACSIL Interface - Custom Chart Bars
[2023-05-16 19:39:46]
Thanks John. Is it possible to get a copy of the ASCIL program behind the Aligned Renko chart type for all the "Renko Bar New Bar Mode Lists" available within SC? It would be easier for me to use existing code as a starting point. If this is not possible, could I hire you guys and pay for this custom programming? I just need the logic to build new bar time at 6 custom times (passed via parameters in the study that I can configure) during a session. Should be relatively straightforward.
[2023-05-16 20:18:08]
Sorry, but we can not give out that code, and we just do not have time to do custom programming. All of the Renko logic is described on the following page:
Renko Bar Charts
[2023-05-16 21:07:55]
Thanks John. I will go ahead and solicit a programmer to replicate the code to my specifications.
