Date/Time: Thu, 28 Nov 2024 08:53:30 +0000
Monitoring Toggle Status of "Used Attached Orders"
View Count: 273
[2023-05-16 00:48:51]
TraderBiku - Posts: 36
Is it possible to have an indicator or display on the chart with shows/monitors the status of the "Use Attached Orders" function without having to open the chart trade window to check the status manually? I use a hotkey to toggle between the two states ("On" and "Off" with regard to "Use Attached Orders") but am not always able to recall the current status of the toggle, which leads me to having to open the trade window often - sort of defeating the purpose of the hotkey -
Thank you!
Date Time Of Last Edit: 2023-05-16 00:49:19
[2023-05-16 14:19:55]
John - SC Support - Posts: 36350
There is nothing built into the system apart from the Control Bar button that you are already using.
