Date/Time: Thu, 28 Nov 2024 08:45:58 +0000
Only transfer configuration of control bar to second instance
View Count: 299
[2023-05-15 23:09:01]
User132431 - Posts: 4
I believe to copy the control bar settings to a second instance requires copying the Sierra config. If I do this, then also the chartbook configuration and what not is also transferred. Is there a way to just copy the control bar configuration to a second instance and no other settings, as I open different chartbooks in the second instance.
[2023-05-16 13:56:28]
John - SC Support - Posts: 36350
There is not a way to only copy the Control Bar settings. All of the global settings are contained within the Sierra4.config file, which also has the Control Bar settings.
