Date/Time: Thu, 28 Nov 2024 08:36:55 +0000
Spreadsehhet formula Don't works whit multiple formulas
View Count: 272
[2023-05-15 20:45:23] |
Hopeman - Posts: 166 |
Hi, I'm trying to create several crossover conditions, they are simple crossovers, these crossovers go together with some conditions in the cells O3,Q3,X3,Y3,AD3,AF3,AK3,AM3,AO3,AT3,AZ3) the formula is as follows =AND(OR(CROSSFROMBELOW (ID0.SG4@3:ID0.SG4@5, ID7.SG1@3:ID7.SG1@5), OR ( ID0.SG4@3:ID0.SG4@5, ID7.SG2@ 3:ID7.SG2@5), OR( ID0.SG4@3:ID0.SG4@5, ID3.SG3@3:ID3.SG3@5), OR( ID0.SG4@3:ID0.SG4@5, ID3.SG19@3:ID3.SG19@5)),O3,Q3,X3,Y3,AD3,AF3,AK3,AM3,AO3,AT3 ,AZ3) I have tried several configurations and none of them work changing the parentheses, even creating a crossfrom to each of the formulas and it doesn't work, would you be so kind as to help me solve the problem, thanks |
[2023-05-15 20:45:50] |
What exactly are you getting in terms of an error? Or are you not getting an error, is it just not working as expected?
