Date/Time: Thu, 28 Nov 2024 08:26:35 +0000
Trade Activity Log - Dates
View Count: 333
[2023-05-15 15:44:08]
Statman43 - Posts: 15
I am running my Trade Activity Log and asking for dates of All Activity between 05-01-23 to "Today". However I only get activity between 05-10-23 and 05-12-23 (which 05-12-23 was the last day I was active). Why am I not getting any activity for dates between 05-01-23 and 05-09-23>
[2023-05-15 16:39:58]
John - SC Support - Posts: 36350
We know it's a silly question - but did you actually have any trades on those days?
Also, make sure all the other options for filtering the different trades are as open as they can be. Make sure you are selecting all the symbols, and the correct trading account, etc. Refer to the following:
Trade Activity Log: Viewing Historical Trade Activity
If the above does not solve your issue, then take a look at the file system and see if there are files for those dates in the "TradeActivityLogs" folder under your main Sierra Chart installation folder. If you do not have any files for those dates in that folder, then this would be why there is nothing to show in the Trade Activity Log. We can not help with missing files, you would need to figure out what might have occurred for them to not be in the folder.
[2023-05-15 21:13:24]
Sierra_Chart Engineering - Posts: 17200
Maybe the data is no longer present.
It might have been automatically deleted based on this setting:
Global Trade Settings Windows: Automatically Delete Trade Activity Log Files on Startup Older than Days (Global Settings >> General Trade Settings >> General >> Trade Activity)
In the case of CQG you cannot recover that data. With Teton order routing you can.
