Date/Time: Thu, 28 Nov 2024 08:38:24 +0000
No data while connected to Teton
View Count: 251
[2023-05-15 13:56:30]
BenjFlame - Posts: 324
several problems:
1) If I connect to Teton order routing (with AMP - they should have me setup for teton) I receive no streaming data (I'm subscribed to Daneli).
2) If I connect to "SC Data all services" i receive streaming data but can't place orders.
Can you please check on your end if you have what's wrong thanks
[2023-05-15 16:15:17]
John - SC Support - Posts: 36350
Set your system to connect to your Teton Order Routing Service.
Then open your Chartbooks and select Edit >> Translate Symbols to Current Service.
If you are not getting the data, then we would need to see your Message Log by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Tell us about *one* symbol only.
