Date/Time: Tue, 15 Apr 2025 14:34:41 +0000
Indicative Futures Open
View Count: 403
[2023-05-15 07:29:34] |
StephenL - Posts: 120 |
Hi guys, Is there a way to see the indicative open price for futures contracts coming into the open? E.g. CME CLM3 indictive open at 16:59CT on Sunday just prior to the market open at 17:00CT. Thanks |
[2023-05-15 09:37:03] |
Sierra_Chart Engineering - Posts: 19228 |
Yes you can look at the Bid/Ask Average Line: Chart Menu: Bid Ask Average Line (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-16 07:00:50] |
Thats the one, thanks
[2025-04-04 08:19:48] |
Can I ask an additional question: is there a way of knowing in the pre-open what the indicative volume will be at the open? The sum of the size of the bids and offers in the pre-open auction
[2025-04-04 13:22:35] |
John - SC Support - Posts: 39275 |
There is not a built-in method to get the Market Depth at a particular price level. To do this, you would need to create a custom study. Refer to the following: ACSIL Interface Members - Functions: sc.GetAskMarketDepthEntryAtLevel https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
