Date/Time: Thu, 28 Nov 2024 08:51:00 +0000
Time By Price Level
View Count: 452
[2023-05-13 23:34:24]
User688525 - Posts: 259
Hello Sierra Chart,
Is it possible to display the time spent in seconds at each price level? This is similar to displaying volume at each price level, but instead, displaying time spent at each level.
Thank you
[2023-05-15 14:37:06]
John - SC Support - Posts: 36350
There is not any support for this. The closest we have is in the Numbers Bars Calculated Values 2 study, which has Subgraphs for "Time since Price Touched Bar High" and "Time Since Price Touched Bar Low".
The only way to do what you are asking for is to create a custom study to track and keep this information. Refer to the following:
How to Build an Advanced Custom Study from Source Code
[2023-05-16 05:25:21]
Hi John,
For the custom study suggestion, as the link you have provided states the following: "The source code for some studies, this includes the Numbers Bars, Volume by Price, TPO Profile Chart, TPO Value Area Lines, Volume Value Area Lines, Study/Price Overlay, Market Depth Historical Graph studies, are not provided or available.", do you have any suggestions on how to go about this considering that "time spent in seconds at each price level" would typically be calculated with the TPO Profile Chart and TPO Value Area Lines studies?
[2023-05-16 09:20:45]
Sierra_Chart Engineering - Posts: 17201
The way that works is that if the price trades within a particular time block, by default 30 minutes, then that price is considered to have traded within that 30 minutes time block. Even if it only spent one second there.
Date Time Of Last Edit: 2023-05-16 09:20:55
