Date/Time: Tue, 18 Feb 2025 22:43:18 +0000
a spreadsheet for a list of stocks
View Count: 525
[2023-05-13 18:24:37]
User409050 - Posts: 22
Hi SC,
I want to create a spreadsheet to track a list of stocks that I am monitoring. The spreadsheet should include columns for daily, weekly, and monthly performance, as well as volatility, in the future, I plan to add additional statistics such as 52-week high and low and some other statistics. After reviewing the documentation, I see that I have two options:
Open multiple charts and add a spreadsheet study to each, although this is not recommended by SC.
Open one chart and add an "additional symbol info" study for each of the stocks, although this process can be cumbersome and slow.
Are there any other ways to create this spreadsheet that would be more efficient?
[2023-05-14 06:23:06]
User800326 - Posts: 2
Hello, new user here. I am looking to find the same answer. I hope some guru of this forum will help us.
[2023-05-15 14:41:16]
John - SC Support - Posts: 38029
Take a look at the Quote Spreadsheet and see if this will do what you want:
Getting Quotes: Quotes on Spreadsheets
[2023-05-15 18:30:30]
Thanks for the reply. I think that OP and myself are trying to use Quote on Spreadsheet with additional data (eg. 52-week high) with respect to the standard fields.
OP says
I agree with OP not having myself found any way to add studies' values to multiple symbols in the Quote on Spreadsheet (or, alternatively, in a Spreadsheet) in a flexible and simple way.
[2023-05-16 09:37:30]
Sierra_Chart Engineering - Posts: 18484
Also have a look at the Study Summary:
Study Summary Window
