Date/Time: Thu, 28 Nov 2024 08:42:32 +0000
global tool settings not showing value and original value
View Count: 290
[2023-05-13 14:14:28]
User21339 - Posts: 61
reinstalled SC on laptop, global settings>tool settings is not showing value and original value in the first tab which is 'general'
Under view it makes no difference if i have ticked or unticked the two options 1. show original values and 2. show search box.
I have reinstalled and updated to latest version.
So I am unable to change the values in that first tab
I only need access to the Drawing Font option so if there is a workaround that would do... although ideally i would rather a solution to access that whole tab to change values.
[2023-05-13 14:29:37]
User431178 - Posts: 544
Increase the size of the window or decrease the size of the Setting Name column.
[2023-05-13 14:35:53]
changing the window size does not reveal other columns. Ive even plugged in another monitor to see if resolution is an issue.
i can ony decrease the setting name column if i can get the mouse to highlight the end of it which should turn red but this is not showing.
Can i globally change the size of the setting name column to view it?
[2023-05-13 14:57:28]
How much bigger did you make it?
The fact that you did not find the end of the setting name column yet means probably not big enough.
[2023-05-15 14:28:00]
John - SC Support - Posts: 36350
If you can give us a an image of what you are seeing, it would help us to understand what is occurring. You can take an image by following these instructions:
