Date/Time: Thu, 28 Nov 2024 08:37:20 +0000
[User Discussion] - Change behavior of BE button. Also question about CME data fees.
View Count: 306
[2023-05-12 18:27:20]
User394081 - Posts: 12
Is there a way to change the behavior of the "Break even" button to move my stop to breakeven + 1 tick (or 2-3 ticks). I want to have a "net" breakeven that includes commissions. If not with the breakeven button is there another way to do this without dragging the order or entering it manually?
Also, I need to run SC simultaneously on 2 laptops. Laptop 1 requires full market depth, but laptop 2 only requires top of book data. Is there a way to purchase only "top if book" data for the second laptop?
[2023-05-12 20:17:59]
John - SC Support - Posts: 36350
You can define an "Offset" for the BreakEven button, so the move will not be to exactly the BreakEven amount. Refer to the following:
Basic Trading and the Trade Window: Set >> Move to BE Offset
[2023-05-16 09:03:48]
Sierra_Chart Engineering - Posts: 17200
No:
