Date/Time: Thu, 28 Nov 2024 08:46:08 +0000
Changing TickSize
View Count: 249
[2023-05-12 10:01:14]
User225678 - Posts: 1
Hello, is there a way to change TickSize (available in ShartSettings > Symbol > SymbolSettings) with:
- a hotkey, OR
- a button on the menu (control bar)
regards, Marcin
[2023-05-12 13:44:48]
John - SC Support - Posts: 36350
There is not a way to do this directly. You would have to create a custom study and tie a Control Bar button to it in order to do what you want. Refer to the following:
Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events
