Date/Time: Thu, 28 Nov 2024 11:01:38 +0000
How much historical data is included for ES?
View Count: 273
[2023-05-11 19:31:27] |
User626228 - Posts: 1 |
Hi, I looked at a previous post regarding the amount of tick data, and am aware that tick data does not go back 5+ years. Since the packages say the data goes back 10+ years, and the numbers differ, what is the amount contracts that I can replay for ES? Thank you. Matt |
[2023-05-11 21:41:56] |
The ES has tick-by-tick data going back to approximately 2011. We do not know why you are saying that it does not go back beyond 5 years. There are limitations when you are using a trading service that uses a single digit year. In this situation, we can not give data more than 7 years back. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
