Date/Time: Thu, 28 Nov 2024 11:01:01 +0000
URGENT: NOT RECIEVING LIVE DATA ON SIERRA CHART SC/TT FUTURES ORDER ROUTING
View Count: 373
[2023-05-11 08:12:36]
User309103 - Posts: 12
HI
AS I HAVE STARTED TRADING I AM NOT RECIEVING LIVE DATA ON SIERRA CHART SC/TT FUTURES ORDER ROUTING
#URGENT RESOLUTION REQUIRED AS MY POSITIONS ARE THERE I HAVE TO LIQUIDATE THEM
imageScreenshot 2023-05-11 085442.png / V - Attached On 2023-05-11 08:11:00 UTC - Size: 215.67 KB - 78 views
imageScreenshot 2023-05-11 085432.png / V - Attached On 2023-05-11 08:11:18 UTC - Size: 1.48 MB - 72 views
[2023-05-11 09:57:52]
Sierra_Chart Engineering - Posts: 17201
We want you to do the following:
Be sure to reconnect to the data feed as well.
Translate the symbols with Edit >> Translate Symbols to Current Service to make sure they are correct:
Edit Menu: Edit >> Translate Symbols To Current Service
Also disable Trade >> Trade Simulation Mode On if it is enabled.
Date Time Of Last Edit: 2023-05-11 09:58:37
[2023-05-11 10:22:12]
SC/TT Futures Order Routing | Starting real-time market data updates for: MNQM23-CME. ID: 2 | 2023-05-11 15:51:07.216
SC/TT Futures Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: MNQM23-CME | 2023-05-11 15:51:07.216
SC/TT Futures Order Routing | Requesting security definition data for: MNQM23-CME. ID: 2 | 2023-05-11 15:51:07.216
[2023-05-11 10:37:23]
This is not the correct symbol. The correct symbol is:
MNQM23_FUT_CME
You can set this through Chart >> Chart Settings >> Symbol
[2023-05-11 10:43:58]
HI I AM NOT ABLE TO SEE CME EXCHANGES IN THE FIIND SYMBOL OPTION, WHILE USING SC/TT FUTURES ORDER ROUTING , IT WAS SHOWING EVERYTHIN TILL YESTERADAY
imageScreenshot 2023-05-11 114213.png / V - Attached On 2023-05-11 10:42:25 UTC - Size: 32.57 KB - 66 views
[2023-05-11 11:01:12]
One moment. We understand what the problem is now.
[2023-05-11 11:01:47]
