Date/Time: Thu, 28 Nov 2024 11:03:28 +0000
Spreadsheet Study
View Count: 336
[2023-05-10 20:54:32]
User841161 - Posts: 221
For some reason cannot open the spreadsheet study that shows to be there.
imageSpreadsheetStudy05-10.PNG / V - Attached On 2023-05-10 20:54:19 UTC - Size: 73.97 KB - 59 views
[2023-05-10 21:16:13]
John - SC Support - Posts: 36350
The first thing is to select the "CW" menu at the top and then select the spreadsheet from there. See if it comes up when you select it this way.
If not, then the window is off the edge of the viewable area of Sierra Chart. The easy way to solve this is to select "Window >> Cascade", and all of your windows will show up in a diagonal in the main area. You will have to reset the positions of the windows where you want them, but you should get the spreadsheet back.
