Date/Time: Tue, 26 Nov 2024 02:01:50 +0000
Error message downloading data
View Count: 434
[2023-05-10 14:42:09] |
User148824 - Posts: 10 |
Hi, I am getting the following error message: Download failed Error downloading historical intraday data for SPY. Historical data logon error: Data files folder not set for service code: us_equities_utp_cta_exchange.data |
[2023-05-10 15:03:20] |
John - SC Support - Posts: 36286 |
You need to update to the latest release in order to get that data. Note that you will only get delayed data as you are on Package 3. If you want real-time data, then you will need to be one of the Integrated packages and then go through the instructions to get the "U.S. Equities Consolidated Tape" exchange. Refer to the following regarding the packages: Description of Service Packages and Pricing: Packages And refer to the following instructions for the "U.S. Equities Consolidated Tape" on our Denali Exchange Data Feed: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-29 08:54:48] |
User851058 - Posts: 9 |
Yeah, but what has changed in SierraChart? I started getting the same error for trying to load intraday data, e.g. for H1 on some NASDAQ/NYSE symbol, BUT it works fine for historical data like D1. I remember it used to work without this error some days ago. I checked the General Settings -> Data files folder and I have it filled in with correct path. |
[2023-05-29 09:00:19] |
Sierra_Chart Engineering - Posts: 17179 |
First thing you must do is update Sierra Chart to the current version. Instructions: Software Download: Fast Update And then: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-29 09:01:10
[2024-01-15 21:03:52] |
onnb - Posts: 662 |
I have this same issue, sc version 2586, using "SC Data - All Services" I can't download historical intrabday data for stock and getting the same error message |
[2024-01-15 22:58:40] |
The issue today is due to the following: Resolved: Data Center Notice for CH1: Data Feeds Affecting! Please read! For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
