Date/Time: Thu, 28 Nov 2024 07:55:06 +0000
TETON with AMP
View Count: 1714
[2023-05-10 13:55:33] |
User192475 - Posts: 3 |
Hello, how do I trade CBOT with teton CME order routing. Thank you
[2023-05-10 14:43:02] |
Sierra_Chart Engineering - Posts: 17200 |
Follow the instructions here: Sierra Chart Teton Futures Order Routing: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-18 08:14:48] |
User68acg - Posts: 15 |
Hi. I swapped from using CQG AMP and Sierra Denaly L11 to Teton . I requested Teton Data for Sierra with AMP and agreed, I have DEnali etc incl cme in SC and I cannot trade live. What am I missing ? None of your support links point to this new version of teton . What is the min amount needed in the account for live tradlig? I do seem to be getting good fast correct data. In SC settings I have selectedTeton CME Order Routing and AMP ad clearing firm. Apart from wihin Sierra where I have paid for CME etc do I have to do that somewhere within AMP or... ? Very frustrated as there is minimal instructive help - that I can find anyway. Thanks |
[2023-05-18 10:20:07] |
and I cannot trade live. What exactly does this mean? Is an order getting rejected?None of your support links point to this new version of teton . Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-18 10:53:03] |
That documentation is useless. I have seen it a dozen times. It tells me to do what I have done but my attempts at placing orders do nothing. I see the order pop up and it just goes away. It is as if with CQG amp my account got too low. That is why I ask what the minimum is. The other thing is, Do I have to somehow pay for cme data in the amp site? I thought paying in Sierra was enough. Thanks |
[2023-05-18 11:34:12] |
BenjFlame - Posts: 324 |
Did you convert your symbols when asked to? I was not able to place teton orders until I converted the symbol of my chartbook to be compatible with teton when asked to. I was thinking it was not necessary since i was already using Daneli for data... but apparently Teton nomenclature is different. I'm also on Daneli, Teton + amp and pay all to Sierra nothing to AMP (except commissions) Date Time Of Last Edit: 2023-05-18 11:34:57
[2023-05-18 12:07:33] |
You must be receiving an order rejection. Check the Trade Service Log for the reason and contact your broker for help with that: Trading Information Windows: Trade Service Log No you do not: Do I have to somehow pay for cme data in the amp site?
