Date/Time: Thu, 28 Nov 2024 10:38:15 +0000
[Programming Help] - Question about exiting trading positions using ASCII
View Count: 363
[2023-05-10 12:21:20]
User395175 - Posts: 87
Hi, suppose i submit 1 buy order with its target and stop attached orders at time t1(and get filled), then i submit another buy order with its target and stop attached orders at time t2(also get filled). At time t3, i have 2 unit long positions and i want to exit 1 unit long position that the first buy order created and cancel that 2 attached orders (target and stop orders, linked to my first buy order, not my second buy order), and don't touch/ modify/ cancel anything related to another 1 unit long position created by my second buy order and its target/stop attached orders.
How can i achieve it using ASCII in my own study?
[2023-05-10 22:42:49]
ForgivingComputers.com - Posts: 960
You need to capture the Internal Order ID of the parent order when the order is filled.
Then you use:
sc.CancelOrder(InternalOrderID);
Automated Trading From an Advanced Custom Study: sc.CancelOrder
[2023-05-11 03:15:01]
I can only use this function to cancel target/stop attached orders, right? Or I can use this to close that position?
[2023-05-11 14:36:50]
You can use it to cancel any order, parent or attached. When you cancel the parent order, the attached orders will also be canceled.
