Date/Time: Tue, 26 Nov 2024 22:21:02 +0000
SC - SCDatafeed - Infinityfutures on the Apple-Mac OS?
View Count: 1660
[2014-06-25 14:29:47] |
User51760 - Posts: 108 |
Hello Support Team, as I understand (since the TransActbridge is integrated now) the combination of Sierra Chart, SC Real Time Datafeed and InfinityFutures/Transact would run on the current Apple Mac OS? Am I correct? Thank you for your answer, Best, Chris |
[2014-06-25 16:40:12] |
We have to leave this question to a user of Apple Mac OS. We cannot give a definitive answer on this. We have heard people do use Sierra Chart on a Apple Mac OS. We are not sure if the TransAct bridge will run properly or not.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-25 16:40:31
