Date/Time: Thu, 28 Nov 2024 09:46:54 +0000
Load times for charts
View Count: 301
[2023-05-09 14:10:46] |
ssangha84 - Posts: 122 |
Hello, when I change time frames on my chart in my second instance, it takes a long time to load. It says its loading some different chart files, but not sure what it is loading. The first instance changes relatively fine. How can I clean up my chartbook so the load times are faster?
[2023-05-09 16:18:51] |
This should not have anything to do with being a separate instance. Most likely it is related to using Market Depth data in this chart versus not using it in another. This is also affected by how many days you have set to load for the chart. You can go through the following section, but our guess is that this is just related to how the charts are setup: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
