Date/Time: Tue, 26 Nov 2024 22:26:08 +0000
Compiler messages
View Count: 1136
[2014-06-25 13:32:07]
ertrader - Posts: 672
Hi support. I am getting the following confusing output from the compiler now. Can you please fix?
- Starting build of Custom Studies Source files: AutoTrendHist8.cpp. -- 08:28:42
"C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\AutoTrendHist8.cpp" -v -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "D:\Sierra_Data\AutoTrendHist8.dll"
Using built-in specs.
COLLECT_GCC=C:\SierraChart\CPPCompiler\bin\g++.exe
COLLECT_LTO_WRAPPER=c:/sierrachart/cppcompiler/bin/../libexec/gcc/mingw32/4.8.1/lto-wrapper.exe
Target: mingw32
Configured with: ../gcc-4.8.1/configure --prefix=/mingw --host=mingw32 --build=mingw32 --without-pic --enable-shared --enable-static --with-gnu-ld --enable-lto --enable-libssp --disable-multilib --enable-languages=c,c++,fortran,objc,obj-c++,ada --disable-sjlj-exceptions --with-dwarf2 --disable-win32-registry --enable-libstdcxx-debug --enable-version-specific-runtime-libs --with-gmp=/usr/src/pkg/gmp-5.1.2-1-mingw32-src/bld --with-mpc=/usr/src/pkg/mpc-1.0.1-1-mingw32-src/bld --with-mpfr= --with-system-zlib --with-gnu-as --enable-decimal-float=yes --enable-libgomp --enable-threads --with-libiconv-prefix=/mingw32 --with-libintl-prefix=/mingw --disable-bootstrap LDFLAGS=-s CFLAGS=-D_USE_32BIT_TIME_T
Thread model: win32
gcc version 4.8.1 (GCC)
COLLECT_GCC_OPTIONS='-v' '-march=i686' '-mtune=i686' '-O2' '-shared' '-static' '-static-libgcc' '-s' '-fno-rtti' '-fno-exceptions' '-o' 'D:\Sierra_Data\AutoTrendHist8.dll'
c:/sierrachart/cppcompiler/bin/../libexec/gcc/mingw32/4.8.1/cc1plus.exe -quiet -v -iprefix c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.8.1/ C:\SierraChart\ACS_Source\AutoTrendHist8.cpp -quiet -dumpbase AutoTrendHist8.cpp -march=i686 -mtune=i686 -auxbase AutoTrendHist8 -O2 -version -fno-rtti -fno-exceptions -o C:\Windows\ccMkSdoK.s
GNU C++ (GCC) version 4.8.1 (mingw32)
  compiled by GNU C version 4.8.1, GMP version 5.1.2, MPFR version 3.1.2, MPC version 1.0.1
GGC heuristics: --param ggc-min-expand=100 --param ggc-min-heapsize=131072
ignoring duplicate directory "c:/sierrachart/cppcompiler/lib/gcc/../../lib/gcc/mingw32/4.8.1/include/c++"
ignoring duplicate directory "c:/sierrachart/cppcompiler/lib/gcc/../../lib/gcc/mingw32/4.8.1/include/c++/mingw32"
ignoring duplicate directory "c:/sierrachart/cppcompiler/lib/gcc/../../lib/gcc/mingw32/4.8.1/include/c++/backward"
ignoring duplicate directory "c:/sierrachart/cppcompiler/lib/gcc/../../lib/gcc/mingw32/4.8.1/include"
ignoring duplicate directory "c:/sierrachart/cppcompiler/lib/gcc/../../lib/gcc/mingw32/4.8.1/../../../../include"
ignoring nonexistent directory "/mingw/include"
ignoring duplicate directory "c:/sierrachart/cppcompiler/lib/gcc/../../lib/gcc/mingw32/4.8.1/include-fixed"
ignoring duplicate directory "c:/sierrachart/cppcompiler/lib/gcc/../../lib/gcc/mingw32/4.8.1/../../../../mingw32/include"
#include "..." search starts here:
#include <...> search starts here:
c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.8.1/include/c++
c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.8.1/include/c++/mingw32
c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.8.1/include/c++/backward
c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.8.1/../../../../include
c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.8.1/include-fixed
c:\sierrachart\cppcompiler\bin\../lib/gcc/mingw32/4.8.1/../../../../mingw32/include
End of search list.
Compiler executable checksum: 1ebc2a6f92fbd3aadc367a20a63fdf9f
c:/sierrachart/cppcompiler/bin/../lib/gcc/mingw32/4.8.1/../../../../mingw32/bin/as.exe -v -o C:\Windows\cc22Xzhx.o C:\Windows\ccMkSdoK.s
GNU assembler version 2.23.2 (mingw32) using BFD version (GNU Binutils) 2.23.2
COMPILER_PATH=c:/sierrachart/cppcompiler/bin/../libexec/gcc/mingw32/4.8.1/;c:/sierrachart/cppcompiler/bin/../libexec/gcc/;c:/sierrachart/cppcompiler/bin/../lib/gcc/mingw32/4.8.1/../../../../mingw32/bin/
LIBRARY_PATH=c:/sierrachart/cppcompiler/bin/../lib/gcc/mingw32/4.8.1/;c:/sierrachart/cppcompiler/bin/../lib/gcc/;c:/sierrachart/cppcompiler/bin/../lib/gcc/mingw32/4.8.1/../../../../mingw32/lib/;c:/sierrachart/cppcompiler/bin/../lib/gcc/mingw32/4.8.1/../../../
c:/sierrachart/cppcompiler/bin/../libexec/gcc/mingw32/4.8.1/collect2.exe --shared -Bstatic -e _DllMainCRTStartup@12 --enable-auto-image-base -o D:\Sierra_Data\AutoTrendHist8.dll -s c:/sierrachart/cppcompiler/bin/../lib/gcc/mingw32/4.8.1/../../../../mingw32/lib/dllcrt2.o c:/sierrachart/cppcompiler/bin/../lib/gcc/mingw32/4.8.1/crtbegin.o -Lc:/sierrachart/cppcompiler/bin/../lib/gcc/mingw32/4.8.1 -Lc:/sierrachart/cppcompiler/bin/../lib/gcc -Lc:/sierrachart/cppcompiler/bin/../lib/gcc/mingw32/4.8.1/../../../../mingw32/lib -Lc:/sierrachart/cppcompiler/bin/../lib/gcc/mingw32/4.8.1/../../.. C:\Windows\cc22Xzhx.o -lstdc++ -lmingw32 -lgcc -lgcc_eh -lmoldname -lmingwex -lmsvcrt -ladvapi32 -lshell32 -luser32 -lkernel32 -lmingw32 -lgcc -lgcc_eh -lmoldname -lmingwex -lmsvcrt c:/sierrachart/cppcompiler/bin/../lib/gcc/mingw32/4.8.1/crtend.o
-- End of Build -- 08:28:45
[2014-06-25 13:44:04]
the DLL is still created and works....just confusing output.
[2014-06-25 16:09:16]
This additional output will be removed in the next release.
