Date/Time: Thu, 28 Nov 2024 10:01:05 +0000
acsil programing and numbers bars calculated values
View Count: 492
[2023-05-08 12:26:03] |
User841206 - Posts: 1 |
Dear sir, I wrote a simple code as a sudtom study so and I need your kind help. In my code, I used "numbers bars calculated values" study. Suppose the delta number is equal to positive 100 and I entered the "Percent compair thresholds (ln17)" formula 0.2, 0.3, 0.4 Now I want to see in which color range this number (100) is placed among the eight ranges. How can I recognize in which range each number falls in coding by acsil programing? Regards |
[2023-05-08 19:35:48] |
Sierra_Chart Engineering - Posts: 17201 |
You will have to access that particular value from the Study Subgraph and then compare it to the different percentages which you would have to code into the study, which you can also make Inputs for, and determine what range it is within.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-08 19:36:06
