Date/Time: Thu, 28 Nov 2024 01:45:56 +0000
Volume Profile settings and position on the left of the screen
View Count: 984
[2023-05-08 07:27:55] |
Mustang77 - Posts: 122 |
Hi I have a volume profile on my candles chart and i have 2 questions. 1- i want to to have it on the left of the screen instead of the right, so i go to the study settings and set "Right align volume bars" and set it to NO, but it doesn't do anything, it stays on the right of the screen. How do i place the profile on the left of the screen ? 2- i want this profile to start at the beginning of each new week and finish at the end of the week, how do i set that up ? Thank you in advance |
[2023-05-08 08:02:44] |
Sierra_Chart Engineering - Posts: 17199 |
1. There is not a specific option to align a volume profile to the left. However, there is this option which is like this: Volume By Price Study: Always Display Last Profile Within View 2. Set this input to Weeks: Volume By Price Study: Time Period Type for 'Fixed Time' Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-19 09:03:50] |
Hi 1. There is not a specific option to align a volume profile to the left. However, there is this option which is like this:
I thought because there is an option that says "right align volume bars yes/no " there would be a possibility to set the profile on the right, i want to have for example a weekly profile on the right and a monthly profile on the left. The fixed range volume profile can be set on the left for example, but i have to manually draw the profile from point A to point B 2. Set this input to Weeks:
Thank you for this, what if i want to set it to last week, not current week, how do i do that? i want the previous week profile on the chart, and i want to move to current week when we pass to next week, in other words it should automatically calculate volume for previous week. How do i set it? Thank you |
[2023-05-19 16:25:38] |
2. Refer to: Volume By Price Study: Number Of Periods Back To Reference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-21 21:25:34] |
2. Refer to:
This setting only applies when the Volume Graph Period Type Input setting is set to Multiple Profiles Based on Bar Count or Multiple Profiles Based on Fixed Time. It does not apply to any other Volume Graph Period Type. I am not using multiple profiles, only one profile, and i want it set to previous week. |
[2023-05-22 13:42:50] |
by the way, this doesnt work, we started now a new week and the profile is still set to last week |
[2023-06-08 13:34:38] |
Do you know why this is the case?: by the way, this doesnt work, we started now a new week and the profile is still set to last week
This should not be the case. What is this Input set to? Volume By Price Study: Number Of Periods Back To Reference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-08 13:35:28] |
This setting only applies when the Volume Graph Period Type Input setting is set to Multiple Profiles Based on Bar Count or Multiple Profiles Based on Fixed Time. It does not apply to any other Volume Graph Period Type. I am not using multiple profiles, only one profile, and i want it set to previous week. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
